Complete Spohn rear end 2007-2011 $300
jeremiahm
Way North CA
Spohn rear control arms and track bar. Fully adjustable if you lift or lower and want to set your pinion angle. 40k miles on them. Good shape. Includes grade 8 hardware and adjustment/rebuild tool for the joints. I went back to factory for simplicity. Spohn's require some maintenance and tightening, they also translate some more road noise, not terrible, but noticeable.
Fits 2007-2011 Yukon, Tahoe, Suburban, Escalade (maybe other years)
$300 shipped in the lower 48. Firm.
Would also consider local trade (Sacramento, CA area) for factory 20" wheels\tires, or tan leather middle bench (Yukon XL).
Thanks,
Jeremiah
Paul_Kaos
Thanks,
Jeremiah
DAMN IT, I paid basically this for the bushinged knock offs from eBay in ******* july bro...
mind if I ask why you took them off?
duke90
Corona, CA
Yeah I think the instruction sheet said to torque to like 70/75 but that was way too loose. I ended up tightening to like 120. Drove around for a few days and then it started clanking and making a ton of noise. Had to tighten again. After the second go-around they've been fine.
jeremiahm
jeremiahm
Way North CA
I took them off to simplify maintenance. They do need to be retightened over time which requires removing them. My Yukon is stock so I went back to stock. They are great if you can use the adjustments.
jeffg
I am on my 2nd round of adjustment. They seem good for a couple of days and then get noisy again. Did you ever use thread locker or anything during the adjustment? I didn't see that in the instructions, but I might have to resort to it.
spectol
