Wheel specs for 2023 High Country 22 inch factory wheels???
Antonm
I looking to put aftermarket wheels (wanting to go down to 20 inch wheel from the factory 22 inch ones), but I'm having trouble finding the specs (width, offset, backspacing) of the factory wheels.
It's a 2023 Tahoe High country 4x4 with air ride, not looking to lift it or modify the suspension, just want to go a 20 inch aftermarket wheel and an all terrain tire (wife loves to run the tire sidewalls into curbs, so I need a thicker/ more rugged sidewall tire for her), but without knowing what the stock wheel specs are, it's really hard to pick an aftermarket wheel that'll work.
Any insight on stock wheel specs or what wheel and/ or tire size (in a 20 inch wheel) would work on a stock suspension high country with air ride would be appreciated. Thanks
You should be able to see your existing wheel specs on the back side of the wheel. You will find the offset there. You should use the same wheel width as your existing wheel, also listed there.
So how do you read the markings and what do they mean?​
If you have shopped for wheels before, you probably have seen numbers like this:
4×100 17×6 ET30
And this is not the only way to write them. In Japan, these numbers are flipped and are written as
100-4h 6jx17+30
These marking above are used interchangeably based on where are the wheels are manufactured at. Based on the marking above, this wheel has four holes, 100 PCD, 17-inch in size, , 6 inches wide with am offset of 30.
Antonm
Antonm
Okay, guess I'll go crawl around on the garage floor with a flashlight when the wife gets home to see if I can get the numbers off the back of the wheels without taking them off.
olyelr
Elk Rapids, MI
The ‘21 and up changed….the ‘20 and back oem wheels wont even fit them.
Antonm
Antonm
I'm not really looking at OEM wheels. Our Tahoe is white (or as GM calls it "Iridescent Pearl Tricoat", which I think is GM's term for "White paint that we just charge you more for"), so I'm looking to put a bronze wheel on it for contrast and maybe tie in with the high country bronze grill accent.
olyelr
Elk Rapids, MI
I understand. Just saying…pick your offset/backspacing wisely, as the new generation suv’s have a different brake setup that wont allow prior wheels to work.
Mark77
You may want to check with your dealer as I thought when you picked air suspension it required the 22 wheels….might be some clearance issue?
Antonm
Antonm
I'll check into it (probably not at the dealer, as I guarantee they'll say it can only accept whatever came stock).
The Z71 can be had with 20 inch wheels and air ride (at least GM's website lets you configure it that way in their "build and price"), the high country always seems to have 22s as part of the package.
Bus 19
Madison, MS
I've found the best place to look for OEM wheel specs is look for them on EBay. If a vendor is selling them, there are nearly always measurements.
As far as smaller wheel diameter fitting. Look at your spare. I have a Z71 with stock 20's, my spare is a 17".
That means a 17" wheel will fit without clearance issues. That's not saying you can slap any old wheel on without problems, but that is a good starting point.
If your spare is a 17" as well, my guess is a 20" wheel would fit no problem.
Antonm
Antonm
I hadn't thought about looking at the spare, great idea. I was just going with that since 20 inch wheels were a factory option, that they'd fit without issue.
BacDoc
Vero Beach Florida
Great idea! I am in similar situation with High Country 22” wheels. They have the Bridgestone tires which have a mediocre rep but I am still amazed by how well the truck rides with the low profile wheels. Maybe it is just because it’s new and less than 2k miles.
The bronze 20” with taller tires is the way I am going. I was thinking of either selling my 22” wheels/tires or just storing them for when I trade in or sell my High Country.
The stock low profile wheels look very nice but almost too blingy/pimp for me and I would love to try 285-275/60R/20 to see if that is even better ride.
The Whip
