TC shudder just started...
PA-WOODCHUCK
Flud was changed when purchased at 50K miles per TSB now at 95K. happens even in trailer tow mode. Does GM assist in repair? does additional damage occur if driven? Will another fluid change help? Please educate me?
BTW I have
2016 Yukon 6.2 and 8speed. I think TC just started to shudder, and how could I check this with Solus Edge(18.3 software). No faults yet... is there a way to record what TC/TCC is doing and how?
thanks
NickTransmissions
Sin City
The transmission bench
BTW I have
thanks
Look at the TCC efficiency, duty cycle and slip (rpms), specifically.
There's class action suits against GM on those things. Pull the trans and replace the converter - contact GM to see if there's a recall or warranty you could claim.
mics
Excuse my ignorance… How do you know it’s a TC shudder and not something else?
P
PA-WOODCHUCK
Dealer checked it, but going to have local trans shop pull pan and check. Both say there is newer fluid. shop road-tested vehicle. I'll update. Trans shop
Dealer also said fluid used in TSB only lasted for about 4 years, hence the newer version of fluid.
waterman
Sorry to hijack thread, are the tsb notices the responsibility of the dealer to inform the customer or is it the customers responsibility to see if there any tsb notices?
P
PA-WOODCHUCK
Not the best photo due to shop lights, but doesn't think it's self-destructing. Doing new filter, flush, newest fluid, friction modifier, then drive.
P
PA-WOODCHUCK
UPDATE: did flush and filter with current spec fluid. Lines were flushed along with 12+ qts and used Ford friction modifier which shop felt better choice. 2500 miles now and all OK!
Question for NickTransmissions when in trailer mode does TCC get locked up and if so what gears?
thanks
Samiam5
Just got the trans replaced in my 16 xl Denali. Started with the shudder said it was torque converter luckily warranty company approved whole replacement on the trans
NickTransmissions
Sin City
thanks
Not sure off hand with respect to the tow-haul mode TCC apply strategy for the 8Ls as Im not familiar with them. That said, glad you are back in business with a reliable vehicle!
scottd
