Rattle/grinding noise at 25-35 mph, mechanic told me AFM and lifters need to be changed.
iboughtatahoe23
2014 Tahoe 167k miles.
I’ve posted one thread about this recently that seems to have gone dead. So I’m making a new one.
Noise I’m having will usually happen from 25-35, mph when i accelerate around those speeds lightly. It seems to only happen in v4 mode and then when it “jerks” into v8 mode the rattle goes away. It’s a very audible rattle/scrape like dragging solid metal behind you. People look at me when driving down Main Street.
8/15/23:
Went to the shop again and took a ride. The mechanic told me i most likely will need lifters changed and it’s gonna run about $2500 or more.
On the other hand: My dad told me I should run 15w40 Rotella and I should be able to get another 150 K out of it but I think he’s blowing smoke just a little bit haha.
Wht you guys think? I’m kind of nervous to just take out a loan and throw money at some thing. But I’m pretty sure if it only happens when switching out of v4 and going into full V8 then I’m almost 90% sure it’s AFM related.
Dustin Jackson
Without doing any troubleshooting myself, a cheap way of finding out if v4 mode is causing your problem would be to buy a tuner or Range AFM disabler and turn v4 mode off and see if your problem persists, from there you can make a more educated decision.
It sounds like your dad is thinking of another Chevy problem but his idea wouldn’t help here really.
iboughtatahoe23
iboughtatahoe23
Thanks, I was considering the range AFM disabler. Probably the cheapest fix tbh.but I have an issue where the radio lights draw power (left sunroof open and that’s what I get for doing that) and I’m afraid the disabler may run my battery dead on top of that radio issue. (I get slow cranks on the first start of the day sometimes)
Can it just be unplugged when not using it I suppose? Then plug it in before I start her up?
Lastly, is there any cheaper brands than the $230 range brand ones?
Dustin Jackson
@iboughtatahoe23 My thought behind the Range AFM disabler was we can take v4 mode out the equation if that is what you suspect is your problem. There are many different ways to go about turning off v4 mode, I would suggest you do your own research on those. I only have experience with Range AFM disabler and Black Bear Performance tune.
I wouldn't be worried about it drawing power while off, if it does you have other problems going on that aren't because of a OBD2 device.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Yes it can. But I don't see the need to at all. This is a simple, must have for these trucks, unless you can do a tune or delete. Pricing wise even used ones hold their resale value. I would get one ASAP then go from there.
Dustin Jackson
@iboughtatahoe23 Just so I understand correctly, when you put the Tahoe shifter in M mode and drive it like that you do not have the problem?
If that fixed your problem then I would recommend getting AFM tuned out of your Tahoe engine computer and continue to enjoy it until you have a lifter failure and then at that point I would recommend a mechanical AFM delete, no point in throwing money at the motor yet.
Dustin Jackson
@the 18th letter I hear where you are coming from. There are other options that are certainly less risky and inconvenient but for $75 this is hands down the cheapest option.
You could always source a new ECU and for $100 they will program it for your VIN and do the AFM delete tune so you'll have 2 ECU in the end.
strutaeng
Dallas, Texas
Are you mechanically inclined any? I think you can get a complete AFM/DOD delete kit including lifters and a camshaft for around $800? YT has a ton of videos of guys doing a cam swap for a step by step. Only difference is you will also be removing the heads to replace the lifters.
Find someone that has HP Tuners and can disable the AFM from the tune permanently.
the 18th letter
Northern New Jersey
I'll just roll with my Range AFM since I hope to trade up in a couple years anyway. Now if I have issues prior to a trade I'd go ahead and just do the whole removal thing.
iboughtatahoe23
iboughtatahoe23
Awesome sauce. Get that tune or Range device ASAP!
weird. It wasn’t doing it when I was manually shifting up. But when I came to a stop sign in 6th gear. It still shifted through all the gears again and when I got up to speed it was still switching between v4 and 8 and was making the noise around those speeds in v4 mode still
Andres Padilla
