2015 Yukon hesitates starting first time in the morning
kakelusa
Hi there, My 2015 Yukon hesitates to start first time in the morning ( 3 or 4 cranks ), once is warm it will start the first time.
I have replaced the spark plugs, replace Air filter, clean the throttle body, any ideas?
Thanks
B-train
Sounds like a fuel delivery issue. Do you hear the pump cycle when you open the driver door after it sits all night? I'm speculating that you're losing volume after it cools and sits, which then needs to be replaced when the initial key crank is commanded. How's the oil smell? Any smell of gasoline?
K
kakelusa
I dont smell any gas outside the car but I check the oil next.
Thanks for the info
markni12301
Just curious, should we normally expect to hear the pump cycle when the driver door is open after sitting all night?
B-train
Yes. I'm not sure what the time delay is, but it's a normal feature on all the new direct injected LT motors I believe.
mrathell
Have you replaced your fuel filter and regularly put fuel injector cleaner in your gas?
avalonandl
Troy, MICH & Naples, FL
Direct Inject engines need to crank for a a couple seconds for HP pump to get fuel to injrctors when first starting. Your vehicle is losing its prime.
Conedaddy
