2017 Chevy Suburban vibration at high speeds
Abdullah576
Hello I have a 17 suburban when going like above 70 mph it starts to kinda vibrate and I can feel it in the floorboard is this an issue with a car or tires?
usually it's tire or wheel related, you could try a re-balance and rotation and see if that resolves it.
also have the alignment checked if it's been more than 6 months.
If you are going to re-balance your tires, I strongly recommend that you go to a shop that has Road Force balancing equipment.
shock
Not sure if you have the tools and the time, but I'd personally rotate the wheels (swap front/back) and see if it changes. A bad wheel or tire on the rear causes the floorboard to shake while one on the front causes the steering wheel to shake.
Even with a "road force" balance some tires just never seem to balance perfectly. My solution this last time was to take off the Goodyears and put on Michelins--seems to work every time.
CRN_25
