front bump stops
SS HOE
Wilson, NC
I have been scanning this site for a few days now and finally decided to sign up. I have a 02 Tahoe and had it dropped with a 2/3 Ground Force kit. The back sat too high for me so I purchased 5" djm springs. I am still running ground force shocks all the way round. Now to my question. I am not nearly as low as some of you guys and my front is nearly sitting on the bump stops. I am running factory bump stops, but they have been cut quite a bit. Just wondering what you guys are doing with them? Appreciate any help.
SS HOE
SS HOE
Wilson, NC
Did you cut out the factory cup on the front before installing the aftermarket stops? I have seen where most have cut out the back and then put the little stop on the frame. Thanks again.
BOSS
The People's A D M I N
Dallas
2005 Z71 4x4 GM bumpstops....will stop you from bottoming out 100% :waytogo:
They are shorter for drops, and reinforced with a lip. No cutting needed whatsoever....search the site for the part number I don't recall what it is sorry.
B
Max
Mile High
Denver
Z71 stops are nice but they lifted my truck 1/2" so be aware. My truck rides better and handles much tighter since installing the stops. Part # on the stop is 15161762 you'll need two.
Narco
Atlanta
did they lift your b/c its already slammed? would mine get lifted any b/c ive only got a slight drop to begin with?
BOSS
Dallas
They lift it slightly because the stops are reinforced with a larger lip like an upside down muffin, so control arm rests against them with no room to compress. It's really not that big of a deal honestly, I can get mine just as low as the fender...maybe max has personal issues :adminpower:
JK max...but the arms are the same on the denalis right?
B
Max
Mile High
Denver
Yes they are the same, my truck is just too damn low I'm gonna decrank it a bit if it really bothers me. Most trucks will not sit higher with the stops unless you're running drop keys decranked.
Dismay
Minneapolis
Basically if the stops are in contact while it's at rest, they may affect how low you can go.
BOSS
Dallas
Not sure if ur asking or telling but yes thats true BUT you ALWAYS want to rest on the stops as much as you can to reduce bottoming out...thats why the Z71 bumpstops are perfect, theres no modification needed,,,perfect out of the box for 2/3, 3/5 and even 4/6
B
SS HOE
SS HOE
Wilson, NC
You have told me to get the z71 bump stops and now I have got the part number. The next question is where to buy them at the best deal. You guys have been a great help and thanks for the quick responses. Wish I had found this site a long time ago.
Durobans
