SOLVED: Loose steering wheel play -- is this normal?? (see video)
Is this type of loose steering wheel play normal for a 2004 Tahoe?
  • Yes
    Votes: 3 33.3%
  • No
    Votes: 6 66.7%
  • Total voters
    9
ggeorgia
Dallas, TX
I've had this annoying loose play at my steering wheel for as long as I can remember on my 2004 Tahoe. I recorded a video of me in the driver's seat with the truck off and in park. I'm able to easily nudge the steering wheel with just a finger. Is this normal?? For instance, was this characteristic of all new GMT800 trucks or something that happens as they age? (I'm been the 2nd owner since 2009, which is why I ask).
Note: I also took footage under the hood to show the intermediate shaft moving with the input shaft of the brand-new steering gear box I recently installed -- so, it's not an issue of the intermediate shaft, as some might suspect (my apologies if this isn't clear in the video, it's difficult to capture, but take my word for it). Even though the input shaft moves, there's no output shaft movement at the pitman arm or at the wheel, for that matter.
In case you're wondering, I've adjusted the tensioning screw (on the previous gear box, not the new one since it will void the warranty and didn't seem necessary), but that never seemed to address this loose play issue.
To give you some background, I've replaced the followed related parts over the course of several years, but nothing has seemed to fix it. :
  • steering gear box, new (2021)
  • steering gear box, remanufactured (2016)
  • intermediate steering shaft, upper and lower (2016)
  • steering shaft bearing (2016)
  • pitman arm (2015)
The latest part I decided to throw at this is a brand-new Lares 11422 steering gear box (top of the bulleted list). Evidently, remanufactured gear boxes only have seals replaced, but none of the wormgear or mechanicals are actually replaced or checked for wear, so it seemed like it would likely fix the issue. To my frustration, after installing, it also had the same sort of loose play I showed in the video. It's maddening!!! I talked to the Lares support staff and they agreed to honor the warranty and sent me a replacement, but that ALSO has the same loose play.
When driving, the new Lares gear box did seem a bit firmer, so it wasn't a total waste, but that little bit of extra play subsists no matter what I do.
If this is par for the course for GMT800 vehicle, then I'll live with it, but I've had no problem fixing any other issue I've had (the latest major repair being cylinder head replacement in December) with the Tahoe, except this. Really appreciate your input!
iddqd
San Francisco, Comifornia, USSA
I'd go and tighten an adjustment screw on a gearbox. I couldn't see in the video if pitman arm is moving with the rotation of the input shaft, but it looks to me like that steering gear adjustment is the culprit.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Yes, steering gear needs to be tightened but should be done in small increments. No more than a 1/4 turn at a time. Road test each time to set the adjustment. Also, check steering gear mount area for any bolt looseness or frame cracks.
Teamiez
Always wondered how good Those new lares boxes are, I have been fighting play myself. Redheads sucked so did reman Delcos best I came up with was a used oem from lkq with 91,000 miles on it
wildcatgoal
I'm not going to say that's "normal" but that is extremely common. I've never come across an old NNBS that didn't have this kind of dead play, some worse than others. I managed to get rid of most if it with my third AC Delco rebuild box (I exchanged them twice) and I had to do some modifications to the lower intermediate shaft (the lower portion of which connects directly to the steering box and is what we are seeing move in this video). Considering you've apparently found a "new" steering gearbox (I didn't know anyone was manufacturing the hard parts anymore), than I would take a very close look at the joint at the bottom of the lower intermediate shaft connecting to the steering box. I found that mine had effectively stretched/opened up overtime and no amount of tightening that little bolt actually got it to lock onto the shaft and it would shift before catching the detent and moving the box. I decided as an experiment to layer aluminum foil over the sector shaft connection on the steering box and shove the lower intermediate shaft on, bolted it down. Once I got enough aluminum foil to fill in the gap I had, most of my play that was similar to this went away. I then tore all of that apart (don't want aluminum mashed together with steel for too long) and basically hammered that lower joint on the lower intermediate shaft down making the hole smaller. That really didn't have the effect that filling the gaps completely did so I took it to a welder and he somehow added material into the hole. Now my clamp bolt locks the lower intermediate joint to the steering box with vengeance and I don't get this play.
Also, I did try a Dorman lower intermediate shaft as a replacement. The joint on it was very tight and proved my aluminum foil trick was right, but the set screw broke inside of it and RockAuto got that back in the mail. Dorman is such garbage every single time.
exp500
As far as steering boxes, the only boxes I have noticed not having any issues has been Blue Top, But only a few uses spotted on these boards. I have had perfect results with Lares, never had to return, GM many returns, repeatedly. PITA. Maybe Lares will fix you up with a good one If you try again. Bench test it before you install by rocking input with a long bar/torque wrench and watch output move or not move.
Joel Ragan Young
After replacing most of the steering and suspension in my effort to get rid of the slop in the steering, and tightening the steering gear box, I drove my '05 for another year before seeing the greatest improvement provided by installing Energy Suspension sway bar bushings. I cannot believe how much that $40 helped the steering. Now, I can feel the sway bar resistance and the steering is tighter on center. I am changing out the rear springs, sway bar bushings and all shocks this week to further improve the ride and handling. I also levelled out using torsion keys.
G
ggeorgia
Dallas, TX
PROBLEM SOLVED!! -- I finally determined that the cause was in fact the lower intermediate steering shaft! Thanks to every for the input, as it gave me some perspective to my situation.
Upon closer inspection at the steering gear box input shaft and lower intermediate steering shaft, I rotated the coupler joint (by hand) and could feel a bit of slop that was difficult to identify by merely looking at the connection. Although the input shaft had a little movement/slop, it was apparent that the majority of the slop could be attributed to the coupler on the lower intermediate steering shaft. I made sure once more that the pinch bolt was properly torqued (33 ft-lbs) but the connection remained sloppy.
As mentioned, I had previously replaced the upper and lower intermediate steering shafts in the fall of 2016 with Dorman parts (big mistake!), so I of assumed that it couldn't be the culprit since the replacement was relatively new. At the time, I was inclined to go with Dorman's design given the history of the original GM intermediate steering shaft and the problems that plagued it for years -- this is evident by the stories of many others on various boards for years. Dorman claimed to address the design flaws of GM, but seemed to have fallen short. I'm becoming increasingly leery of Dorman, as I just had another Dorman part (set of door hinge pin bushings) that was absolute junk. Their quality has completely gone south.
After reading responses from everyone last week and reinspecting, I decided to order a new GM OEM upper and lower intermediate steering shaft from RockAuto. By now, I figured that GM got their act together to fix the design issues. Got the new parts on Friday and installed this weekend. I was able to tell the difference immediately!
Here's the new video for comparison. I'm doing the 1-finger test (consistent with the first video) to demonstrate how firm/loose the steering wheel is when the truck if off:
Really appreciate everyone weighing in on this topic! I picked up some other good ideas Energy Suspension sway bar bushings.
Good news! Please change the thread title by adding "solved" to it. That will help others when they're searching for solutions to a specific problem.
Dorman’s quality has always been terrible. Only trust their parts on non critical components that are easily replaced. There’s very few of their parts that I will use, things like clips come to mind.
As mentioned, I had previously replaced the upper and lower intermediate steering shafts in the fall of 2016 with Dorman parts (big mistake!), so I of assumed that it couldn't be the culprit since the replacement was relatively new. At the time, I was inclined to go with Dorman's design given the history of the original GM intermediate steering shaft and the problems that plagued it for years by the stories of many others for years. Dorman claimed to address the design flaws of GM, but seemed to have fallen short. I'm becoming increasingly leery of Dorman, as I just had another Dorman part (set of door hinge pin bushings) that was absolute junk. Their quality has completely gone south.
What did the new parts run you? Part #'s?
G
ggeorgia
Dallas, TX
Lower Intermediate Steering Shaft:
GM GENUINE 25958109
$146.79
Upper Intermediate Steering Shaft:
GM GENUINE 19329330
$63.79
Steering Gear Box (New, not Remanufactured):
LARES 11422
$334.79
Coupling Shaft Bolt (Replace this if the head seems stripped like mine was. I bought one from ebay since it's not currently in stock on RockAuto.) :
GM GENUINE 26030302
$6.84
GM GENUINE 25958109
GM GENUINE 19329330
Thx
BigDogYJ
Earth
Thanks for this info. I’ve been trying to track down a similar issue after placing the intermediate shaft, column bearing, steering box, idler, pitman and tie rod ends I still had this slop. I’ll try the lower shaft as well. During my research I came across another part number for this lower shaft (25958108). It appears this part number is for the 2500HD/3500 trucks. So for reference : 25958109 is for all 1/2 ton trucks and suvs and 25958108 is for all 2500HD/3500 trucks or any 1/2 ton with a body lift. It’s a bit longer to take into account the factory body lift on these models. This applies to gmt-800 only. These part numbers might fit other years and models
I mention this because of my situation. I have a 2500 Yukon xl with a 1.5” body lift up front. So I ordered the longer one (25958108). The upper or intermediate shaft is the same per number for all models in this series.
dan newman
I went 3/8 of a turn on my steering box, never looked back. I need an idler and pitman arm,,, but it's knot as bad as MR Bentwrench trys to tell me. I am the driver and I'll make that call, I have a whole complete front end kit if and when I feel it's needed. Bilstein gas shocks are worth the money,,, if anyone needs a little push,,,
G
ggeorgia
Dallas, TX
Nice! I've always admired the 2500 series of the Yukon/Suburban. Is that the 6.0L or the 8.1L ?
If you do replace the lower intermediate shaft, definitely make sure to torque down the coupler/pinch bolt to spec (33 ft-lbs per Chilton book). Getting the bolt "tight" may not be tight enough as I initially found out during installation. Only after going back with the torque wrench, did the last of the slop disappear. I was getting a bit nervous myself -- fearing that the bolt might snap off before hearing the click on the torque wrench, but I did finally hear the click (or beep, depending on your torque wrench). When I'm extra paranoid, I sometimes put a digital torque adapter in between a click-type torque wrench and the bit to double-check in case calibration is off.
BigDogYJ
Earth
It WAS an 8.1. It's got an LBZ Duramax/Allison in it now. Hence the body lift to clear the intercooler.
Good point on the torque specs. Steering, brakes and suspension are important things to adhere to torque specs for.
varminpoolteam
