Water pump or not... that is my ?
5strmtrp
Driving to work at 2AM it’s snowing and I have heat.
About half way to work I notice it’s cooler in the truck, nope still have it cranked to Hates level.
Nearing the office, wisps of heat if I’m lucky.
Coolant level the same in the res tank, upper hose feels hot but it’s cold as shit outside. Bottom hose tepid.
Ohh n I’m still here at the office, Napa is a mile away...
Could it be t-stay?
The pump?
Blocked heater core?
wsteele
Was everything working well for like years?
If so, I would guess something electronic versus mechanical. Like one of the temp sensors (duct or cabin).
Geotrash
Dave
Richmond, VA
Radiator hose temps you're seeing are normal. How was the coolant temp on the gauge?
I that's normal and the coolant level is steady, you don't likely have air in the system or a leak. My guess would be the blend door actuator. Common issue.
If your coolant temp gauge reads low, then I would suspect the thermostat is sticking open.
5strmtrp
5strmtrp
Thanks all, coolant temp guage in dash it dead middle 210ish degrees.
Im hearing the door change settings but it seems to me slow.
The hoses are warm hot on the top, like it should be, cool on the bottom.
I didn’t check the hoses going to the heater under the hood, will check when I get home tonight, see what they feel like.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Hopefully it's something stupid brah.
5strmtrp
5strmtrp
Drove it home, temps never went over the norm mark, had heat, enough to keep the windshield from fogging and freezing up. Seems to be its normal self. I did notice after I pressure washed it and put the defroster on a that the Ac switch flashes when depressed and will Not stay on. No matter where I set the dials.
From what I can tell is that it’s not the water pump or t-stat. Either it’s a blocking heater core or the door.
St. Louis
If it's below a certain temperature outside the AC light will do that. Basically a protection mode for the AC system.
Does the rear heat work ok?
I had this problem on my 2001 a couple years ago and thought it was a blend door actuator acting up. It wasn't. I back flushed the heater core and that fixed it.
5strmtrp
5strmtrp
Yup the back heat works as well.
When I bought this truck from Chicago Motors the rear heat wasn’t in the options list.
I had no idea I had it for the 1st few days until I noticed a button that said rear. I thought it was to lock out the rear doors or release the rear glass.
So flushing the system, gather its different that what I used to do on my pickemuptruk. Reason being the rear system?
St. Louis
Not really. Disconnect those plastic factory quick disconnect T's from the heater core inlet/outlet ports at the firewall and do the back flush as usual.
If the truck has some miles on it, I'd just buy new OE disconnect T's and replace them while they're off. They're known to get brittle, crack, and start spewing coolant at the most inconvenient time.
Geotrash
Dave
Richmond, VA
Good advice. If you do that OP, definitely buy OEM tees or get the billet ones from gruvenparts.com. I used the Dorman OEM-style plastic ones once and they lasted barely a year. Don't forget to replace the plastic tee down by the water pump too - and for that one Dorman sells a metal version that comes with the hoses and is superior to factory.
drakon543
are you referring to the vent selection settings or when you adjust the temperature. you should have 2 actuated doors for the hvac. one is typically audible and that would be the vent selector door. the blend door mixes cooler air with the direct heated air to get your desired heat setting. the blend door as mentioned above is the door in reference. if its weak it could be opening farther than it should be allowing too much cool air in the system.
1BADI5
DMV
Yeah if you have rear heat, I'm thinking blend door issue as well.
5strmtrp
5strmtrp
Going to see how much the local steelership want for the fittings.
or
I can combine getting the steering wheel I want along with the fittings, yeah yeah that’s it.
5strmtrp
5strmtrp
What your saying, switching the settings between floor, face, both, windshield floor etc. That’s what I’m referring to. What and where do I listen to for the blend door. What you are saying seems to make sense as far as the warm & cool air mixing.
wsteele
Here is a clip of where the blend door actuator is located and how to replace it.
Good luck.
muncie21
The fact that your lower rad hose is 'tepid' gives me cause for concern. If the engine is at operating temp and the t-stat working correctly the lower hose shouldn't be cool or tepid, unless you've got one hell of a radiator and heat exchange going on.
or it's cold as balls out, in his case "snowing" and probably colder now, if his temp gauge is staying steady "as reported" there is no reason to suspect anything other than a blend door, a clogged heater core is pretty rare yet people want to always presume that is the problem simply because of no heat in the vehicle, 1000x more actuators go bad than heater cores, if it was a really old vehicle not maintained "maybe" his is a 2014 ssv which means it has most likely been maintained at least previous to being civilianized.
johnsonwillie199
