2003 rear hatch actuator
Firstoneman
Northern Michigan
Hello:
Bittersweet post here...just got a 2003 Suburban that belonged to my father because he passed away. I’ve considered doing the following repair for him for a while now, but it was something I put off because he built a box with drawers and it is in the way of getting to the inside panel of the rear hatch. I now need the rear cargo space for hauling stuff from house, etc... I got the seats out of the way and managed to pull the box back away from the hatch far enough for access. Now for the problem. I tried several different search strings on the forum search but couldn’t find it with my ideas.
The rear hatch lock actuator mechanism must be bad because the window button won’t work to open it and the door handle for the complete hatch to lift doesn’t work either. So I need to get a new one. My questions are: 1) can I get that interior panel off without the hatch open and not destroy the panel? (I have to work from the inside with hatch closed) 2) I see prices all over the map for the actuator... $15 to $150. The local junk yard wants $75. What to buy? Rock shows a part from Shee-Mar for $20 - can I trust it? Comes with 2 yr warranty. Otherwise the local shop has one for $125. 3) Is there a way to open the lift gate without that actuator working?
Thanks for your thoughts.
Dave
Cbncanada
You might have more than one problem. Is it electric locks? If so do you hear it try to unlock? Does the window button stay in (not pop back out)?
F
Firstoneman
Northern Michigan
Thank you for thoughts...Yes electric locks. The window button does stay in and if I press around it or thump it it will pop out (that seemed to be happening even when it worked). I’ll go out now and see if I can hear it trying to unlock/lock. Yes I can hear it trying to unlock/lock. Please let me know what that means. Thanks.
*edit: also, the problem gradually turned major...began to have symptoms a few years ago apparently, but would resolve same day often by unlocking and locking a few times, then it would take a day or two before it would open again. The malfunction would extend for longer and longer periods of time until the present reality.
Cbncanada
The window button may be the separate issue. I had the same problem with it on my 2006 Yukon. The solution is to add a spacer into the button assembly inside the hatch. I used a small piece of plastic tubing. See the attached YouTube video
F
Firstoneman
Northern Michigan
Thank you for this info...good to know.
JeffK
