Best brake upgrades
skyhighsami
My Yukon needs brakes bad. I'm seriously considering C6 Z06/GRANDSPORT calipers and 2 piece 15" front rotors and 14" rears but 22" wheels are required I believe. I've also seen GMT900 components used as an upgrade. If Brembo calipers from 5th and 6th Gen Camaro is possible please share all the info. Also I'm calling SSBC to see what they offer and how small of a wheel you can run. My goal is to make a fullsize Trailblazer SS. A fullsize SUV that stops extremely short, runs in the 13s in the quarter, handles like a vehicle it's shouldn't be able too. Thank you and Merry Christmas
Lizard944
I have a 2005 Yulkon Denali and just went with AC Delco Coated rotors and AC Delco pads. Make sure you have good rubber brake hoses and a good flush on the brake fluid to get all bubbles out. I have a very firm pedal and can stop crazy fast. Can't imagine the need for any caliper upgrade.
adriver
Heres the original thread/GB on the custom made bracket to run the brakes.
http://www.silveradoss.com/forums/topic/64830-z06-brake-conversion/
I'll post it up if I see it, and I don't remember where, but I have recently seen someone selling this bracket on one of these forums.
Baer & SSBC also make larger brakes that will work. If you are doing this, do hydroboost too. Sounds like you want to jump right past the NNBS upgrade, (just making sure you are aware of it; a hair bigger rotors, but they are thicker to cool better with a two piston caliper instead of 1, and a bigger pad).
adriver
Found it..
https://www.performancetrucks.net/forums/texas-193/rudy’s-bracket-c6-z06-caliper-553992/
bottomline2000
Dallas, TX
Lots of threads about this, but no one has actually executed it. The custom brackets are the hard parts to make work and you should be able to run the Zo6 rotors with minimum 20" wheels. Not sure about the camaro rotors since the brackets were made specially for the z06 caliper. The wheel type/offset will make a difference as well. Not getting my hopes up, but would like to see someone complete this mod. This would be the next step for me. I had similar goals to basically make a factory freak truck..the best of everything GM made in one truck...that would mean a lsa blower, sub 13 sec truck and this upgrade..even though Wilwoods may be easier to do.
CountryBoy19
Southern Indiana
I just did the gmt900 upgrade. Interestingly the "gmt900" fronts also cross reference to 05-06 1500 trucks w/ rear drum brakes... I didn't know that until I was looking at applications charts.
So far I'm super happy!! I used all Raybestos including their brand new optical calipers (lifetime warranty).
RST Dana
OH
Photos? We are curious
adriver
I spent a night going over this recently. When I tried to save it there was a glitch and I lost pages of the complete information on this. (Was going to be the ultimate complete stickie on this). I plan on doing it again, but here's what I have so far..
2005-2006 SILVERADO/SIERRA 1500 EXCLUDING: Hybrid, SS, HD, & rear disc; Had the larger 13" rotors. (If it had the larger 13" rotors up front, it had rear drum).
------2007 SILVERADO/SIERRA 1500 Had the same 13" rotors but had the same earlier pad # as 05-06 (not sure if thats classic only).
ALL 2007 1500 Full size, ( :Silverado, Sierra, Avalanche, Escalade, Yukon, Tahoe, suburban) Had a different caliper and pad (part number) than the 2008-up. Yet, they all used the same 13" rotor. I don't know what the difference is in caliper, or pad, or if both will work or not for the upgrade.
- YEARS ---- PAD # ------ MODEL ------------------------ YEARS -------- PAD # --
2005-2007 - D1092 - SILVERADO/SIERRA 1500 -------- 2008-2014+ -- D1363
------ 2007 - D1092 - AVALANCHE 1500 ----------------- 2008-2013 --- D1363
------ 2007 - D1092 - ESCALADE (EXCL EXT & ESV) ---- 2008-2015+ -- D1363
------ 2007 - D1092 - ESCALADE (ONLY EXT & ESV) ---- 2008-2014 --- D1363
------ 2007 - D1092 - SUBURBAN 1500 ------------------- 2008-2015+ - D1363
------ 2007 - D1092 - YUKON 1500 (INCL XL & HYBRID)- 2008-2015+ - D1363
------ 2007 - D1092 - TAHOE ------------------------------ 2008-2015+ - D1363
------------------------ EXPRESS VAN 1500 -----------------2009+ ------- D1363
------------------------ SAVANA G1500 ----------------------2010+ -------D1363
CountryBoy19
Southern Indiana
Photos of brake parts? What are you trying to differentiate/see? There is a sticky on the GMT900 brake upgrade that has lots of good photos. If you want photos of the Raybestos parts, give me a few weeks. I have new winter tires coming and I'll snap some pics when I have the wheel off. Otherwise you're getting a pic taken through the wheel. Sorry if I sound lazy, I'm not, I'm just really busy... I go to work all day, spending nearly 2 hrs on the road getting to/from work, work 10 hrs, then go home to newborn twins and 2 older kids (and a wife)... It was enough of a chore for me to get a single saturday to myself to do all the brakes, purge out all the old nasty fluid, and replace/bleed. FWIW, my brake fluild reservoir was SUPER nasty. I'm certain it was the original fluid in there and there was a lot of sediment on the walls. I pulled the reservoir off and cleaned it out the best I could and I bled the brakes until I got clean, clear fluid at each wheels. I bought a gallon of new fluild and was left with about a quart...
As described to me by a Raybestos engineer, the only difference going from those earlier brakes to the later brakes (at least in the Raybestos products) is that the drag-reduction springs for one version was a separate spring and the drag reduction spring in the others is part of the stainless slide clips that are replaceable (are those the abutment clips?).
I also seem to recall discussing with him that one caliper required a special pad that actually engages the caliper piston in a certain way, maybe a retaining clip the goes inside the piston?
I have the 1363 pads and the application chart said they would fit the 05-06 Sierra... but your chart says opposite so I'm not sure anymore. I know the Raybestos engineer said either brake setup will work for my application but the pads have to the right pads for the caliper I have. Since I was buying all-new parts I just bought all new parts that were compatible.
The specific parts numbers I bought are:
FRC11713N Front Right caliper
FRC11714N Front Left caliper
Raybestos 580279FZN Rust Prevention Premium Vented Rotors
EHT1363H Enhanced Hybrid Technology pads (I really like Akebono ProACT pads but had trouble finding them for the rears on my Yukon so I started looking around. Over on BITOG there was a big discussion about Raybestos new EHT pads because better than the ProACT in almost every category, especially when paired with Raybestos premium rotors. So I decided to give them a try.)
H6012 rear drag reduction springs
H6025 front drag reduction springs
FRC11169N Rear Left caliper
FRC11170N Rear Right caliper
EHT834H rear brake pads
adriver
I appreciate that you think I am that knowledgeable, but I have no frickin clue if that's true or even know what half of what you said is. I'll take your word that both work as long as the pads match the calipers. (That was something I have not read in any of the NNBS brake upgrade threads). I have to search more, but I think I can find the specs on the pad size and see if there is any difference
HiHoeSilver
Away!
Chicago
If you go look up calipers for the 2007 (and maybe 2008?), it will ask you which casting number for the caliper. As stated earlier, it had something to do with a retaining clip or something. I'm not sure we ever came up with a definitive answer. In my sourcing, I chose to use 2013 as for part numbers to avoid that whole pile.
CountryBoy19
Southern Indiana
From my understanding, 2013 style is one of the casting number options it's asking you when looking at 07/08. According to the chart adriver posted that would be the calipers that use the 1363 pad.
According to 2005 GMC Sierra 1500 on rockauto, both the 1092 pad (and matching calipers) and the 1363 pad (and matching calipers) were used on the 2005 w/ rear drums, in addition to the brakes that were used for those with rear-discs. What a fluster-cluck for guys trying to replace their brakes. 3 different front pad/caliper combinations used on OE Sierra 1500 brakes.
w/ rear disc brakes used 785 pad
w/ rear drum, w/ hydroboost used 1363
w/ rear drum, w/ vacuum booster used 1092
according to what I could find on rockauto by piecing together "bread-crumbs" left in the applications information for multiple pads. Some of them don't differentiate at all... one thing is for sure, if replacing brakes on these you BETTER know what brakes you actually have before ordering the parts or you'll be very disappointed.
I have hydroboost on my yukon so if there is some sort of "mismatch" that doesn't mix well with hydroboost and 1092 pad-style brakes then I lucked out and ordered the right ones.
HiHoeSilver
Away!
Chicago
Yeah, it's a head spinner for sure.
bottomline2000
Dallas, TX
I think they all use the same front pad. 1363.. Thats what I have on my 2012 escalade calipers.
CountryBoy19
Southern Indiana
If by "they all" you mean 1500s after 2008 I think you may be right but prior to that it was all over the map... it's like gm engineers just picked the flavor of the day on brakes...
adriver
Rockauto has the 1363 with Front; Cal Bracket Cast # 351C/352C &
Rockuato has the 1092 with Front; Cal Bracket Cast # 285C/286C
JF3 11874 P BRK M BRAKE VAC POWER, 17" DISC/DRUM, W/ABS, 7,000 LBS
JF7 11878 P BRK M BRAKE VAC POWER, 17" DISC/DRUM, W/ABS, 6,400 LBS
https://www.rockauto.com/en/moreinfo.php?pk=2043046&cc=1432418&jsn=10701
(Centric 14166052) Shows the Casting difference (for 351C)
Here on the pad, you can see how it mounts is different.
1092 pad
1363 pad
Have both styles on the front of mine and picked up about a 1/4 mpg more. How are the brakes doing now, 18 months later?
varminpoolteam
