5.3 2000 Tahoe question -fluid leak
Tkrysl
Noticed a fluid leak. I think I located the culprit but I've got no idea what it is!
Can you tell me what this little hose is, why it's leaking, and what to do to fix it?
Thanks in advance. You'll see the mess it's making under the wheel well. 5ad474f25f70ab44d801be712bfcbd6b.jpg01f0fdb8f4c3a26b45499eae8630626e.jpg
I don't always venture out into the sub-freezing darkness, but when I do, it is hunting season, and I carry a Remington. Stay hungry my friends.
95escahoe
That looks to be your front diff vent hose
Tkrysl
Tkrysl
Would that fluid be green?! I can't wrap my head around the green fluid.
95escahoe
No clue why it would be green but the vent hose looks like that and it’s on that side
rockola1971
Indiana (formerly IL)
Did some ****** put coolant in your front diff? We want pics of the destruction and mayhem when you have to pull the cover! Extra "Likes" for youtube video of the sounds before teardown.
Tkrysl
Tkrysl
No sounds right now.
Ordering parts for the diff breakdown today.
Prolly do transfer case while I'm at it and some Bilstein shocks.
Tkrysl
Tkrysl
Sorry I didn't capture video. The gear oil looked perfect. Zero wear and I am sure it was well over due for a change. It did have a slight green tint to it. I am guessing it is pushing out the breather tube and when oxygyn hits it, it turns tint.
I still do not know why it is leaking out of the breather tube. I removed the tube and forced air through it several times to make sure it was not clogged or blocked in any way.
Installing some Bilstein's this weekend and will check again when it is up on the life.
MrRuiz
