2011 Wheels on an 02 Tahoe?
Dusty_GMT800
Long Island
I know the lug pattern is the same, but what about the offset? I'm referring to the 17s on the 2011 models, 5 spoke wheels with the bowtie emblem. They have 265/70r17 tires on them. Will these rub at all? Truck is totally stock suspension. May do a leveling kit soon.
NathanJax
Vacation Nathan
Jax, Fl
I know they'll fit fine. I'm not sure on the specs, but they will fit and look fine.
mwilson62000
Senior Member
Yes, no issues with those. I have 2015 18" wheels on my 03 w/ stock suspension. Just need to recalibrate speedo.
massivespl
I'm not mean, I'm honest.
Michigan
Spedo might be off 1-2mph over 60mph... I wouldn't waste money trying to calibrate it
adventurenali92
Big Bear Lake, ca
You will really only need to worry about the speedo if the the new wheel and tire setup is way taller than your stock setup. Like 2 inches taller or more. I went from my stock NBS Denali 17s to 2007+ Denali 20s. My stock 17s were on 265/70/R17 tires and I went to the stock recommended 275/55/R20 tires and the 20s were barely half an inch taller than my stock setup. Speedo is exactly the same as it was before the switch. How much taller are the new tires that you want to put on than You're stock setup?
HeavyHoe03
