Lowering Rear Spring options?
ReyRey
@WillRyan
This is mine sitting at 33.75 in the front.
Like 35 in the back
Truck looks great. It's exactly what I want to do to my suburban. If you don't mind me asking do you have the part numbers for the springs? Thank you
Goodinblack
I Like Tacos
Dirty South
They are the 2 inch drop springs
Look on my build thread I think I listed them there
Sent from my SM-N910V using Tapatalk
Goodinblack
I Like Tacos
Dirty South
Looks like 5301
The 5321 in the classifieds should be close to the same thing. You may can call beltech
ReyRey
Looks like 5301
Okay thank you. Once again your truck looks sick. I can seem to find your build thread though. What kit are you running on the front?
Goodinblack
I Like Tacos
Dirty South
Thank you.
Mcgaughys coil relocation brackets. No kit per se
chilleblanco36
I think if like to try the PPV springs as if like. Little rake if possible. Just installed some escalade 22's. All I need is the rear to sit down a little and I'm good.
GM Part #15200994 taken from the post above
Sent from my SAMSUNG-SM-G935A using Tapatalk
BADRIDES
Got a set of rear Belltech springs for sale if interested.
chilleblanco36
I keep reading they sag. That worries. I don't like sagging. What's your opinion? Any pics of yours with them installed?
BADRIDES
never heard anything about sagging. I took mine out caused they rubbed the frame on the right side of my 02 Tahoe
chilleblanco36
What are you asking for them just in case
BADRIDES
$140 shipped and $277 shipped new on belltech site shipped.
chilleblanco36
Not bad. Trying to decide between the PPV springs. What's the part number on yours if you don't mind
chilleblanco36
Yeah.. not sure how they can sag..
I guess sagging may not be the correct term. The rear sitting lower than the front in due time instead of actually level
KBones
Oh right. Gotcha. They usually can take close to a month to completely settle(depending on your driving)
BADRIDES
It would take years for a spring to sag. I dont think belltech makes products like that especially for what they cost.
Goodinblack
I Like Tacos
Dirty South
They don't sag. The truck looks like it's sagging till you drop the front. Then the springs look like they are too high.
chilleblanco36
So you're saying if I level it with the beltech springs I'm still going to have to lower the front?
The guy with the PPV springs says his has a slight rake to it
KBones
You can put a spacer in with the spring if its too low. Or just get springs that sit at the level you want.
Big Jim
