First Yukon... not first GM
Simhinz
Finally decided to try an SUV, found a 04 Yukon Denali i liked and pulled the trigger. Loving it so far. I join forums for technical support and some info sometimes not found anywhere else.
M1Gunner
Gainesville, Fl
Nice. Welcome to the forums. You know anything about the truck you just bought? Lift and mod details etc?
Miami-Dade
Moderator Supporting Member
Welcome from Miami Beach Simeon!! Love your Denali.
Simhinz
Simhinz
It looks to be a 6" tuff country 4wd lift. Drive line looks modified like its supposed to. Drive shafts have adapters installed. Also 3" body lift spacers. Ive been researching to try and find details but I cant. Apparently this truck was bought in 04" and modified in 05" by a millionaire for desert use, thats the story ive been fed anyway. Truck drives perfect no shakes or vibrations. One thing that will be fixed is the front shock mounts, they used some sort of adapter to mount stock length shocks, and this mount causes the lower inside part of the shock to come in contact with a previously used mount of some sort. It seems the bracket forces a drastic inward articulation.
The light bars were bought and installed at a shop by previous owner. Headlights, turn signals and tail lights are aftermarket (want to replace headlights with the Anzo U halo ones). Everything inside works still. Engine isnt modded but has full catback exhaust 2-1 series 50 flowmaster. The black portion of the 2-tone is a spray on liner type material, i plan to paint those pieces instead.
glazar
