Instructions to remove trim from B-pillar?
DWTahoe
Colorado
I was wondering if anyone had any instructions to remove the interior trim from the B pillars. Specifically I'm tracking down a rattle that appears to be behind the driver seat belt on the b-pillar. It sounds like metal on metal very small when I hit bumps or rough pavement with every bounce.
I have put pressure on the seat belt, the trim on top of the door, the outside black pieces, basically everything I've read about and nothing stops it. I can actually put my ear almost directly on the panel while I'm driving so I'm pretty sure it's behind there.
If any body knows how to get back there I'd appreciate any insight. I'd take it to the dealer but I'm afraid it will come back worse than it is now.
Thanks.
~DW
mbp1979
North Little Rock
The b-pillar is all held in with clips just remove the bottom door sills front and back and it all just unclips pretty simple.
DWTahoe
DWTahoe
Colorado
Okay I just didn't want to start pulling in case i missed something. Sometimes you have to pull a lot harder than you think you should need to...then it's too late. I was looking for a manual or something that showed the location of the clips but that search didn't turn up anything for me either.
Thanks.
Numbnuts3
Thanks.
If you get around to doing this, some pictures of where everything is would really be appreciated. I've been having the same rattle that has been going on in that same exact location. I'd be willing to take my pillar apart if I knew that I could fix something behind it. Let me know what you find out! Thanks.
WingsAA
CMFIC
Dallas, TX
Anyone get this resolved? I'm having the same issue... it's at the dealer now and they heard it initially when riding with me but now that they have it the tech says he can't hear it.
Seems to me it's the belt adjuster or how it's mounted but curious if any of you resolved this.
NYisles1
I've got same issue but from the C pillar...sounds like a slight pop over bumps or whenever the body stresses. Interested to see what you uncover..
WingsAA
CMFIC
Dallas, TX
Mine is a slight constant rattle but right by me head. I truly believe something behind the belt adjuster came lose or a tensioner spring or something came lose and is rattling in that pillar. I emphasized to the dealer today to remove the pillar and have a look physically. The passenger side doesn't rattle and the adjuster is tighter like its has more tension on it where the drivers side seems more lose like whatever was putting tension on it broke or something.
WingsAA
CMFIC
Dallas, TX
Quick update. Dealer completely replaced my drivers B-pillar. No more rattle.
WingsAA
CMFIC
Dallas, TX
Well the rattle was still there. Talked with the dealer about it again and they had the vehicle for two days today total and have it resolved.
Turns out it was a loose retractor bracket. They removed and resecured the bracket and it's been quiet now.
WingsAA
CMFIC
Dallas, TX
Sounds like your exterior trim pieces are starting to come loose. Check these threads all started with a rattle sound behind the seat belt.
http://www.tahoeyukonforum.com/threads/heads-up-black-plastic-door-trim-falls-off.73979/
http://www.tahoeyukonforum.com/threads/2015-suburban-exterior-pillar-covers-popping-off.71188/
I checked them all and they appear to be tight. Not ruling them out but I don't think that's it. I'm leaning more to it being something with the weather stripping and how it touches the interior pillar trim. It only does it when it's sat in the sun/heat. Also, if you loosen the two bolts in the grip handle it's stops the itching/rattle noise. As soon as you tighten them it comes back.
WingsAA
CMFIC
Dallas, TX
After closer inspection... you may be right on those trim pieces. Mine are tight and not flapping but there are a couple locations on them where you can push lightly on them and replicate thr tapping noise. Guess I'll have to take it back in and see if they'll replace them. I'll keep you all posted.
Gilmore
Thanks.
~DW
Just removed the B-Pillar trim. I've been having the same noise you describe. i believe this seat belt guide is the issue as its loose. Held in by a cheap plastic pin.
WingsAA
CMFIC
Dallas, TX
I thought so as well but it's not. I secured it with a bolt, put felt tapebehind it and the rattle still exists. If I keep the two bolts loose in the handle grip... it doesn't rattle.
Gilmore
Well darn, thought I was brilliant for about 2 minutes. I'm going to secure this bracket and see if that helps mine. I also think it could be a rattle in the height adjustment mechanism itself as I can also approximate the sound on that part as well. I will also try the handle screws and see if that works. I've had the vehicle in 5 times with no luck. Dealer has replaced the outer trim pieces to no avail. I've given up on the professionals. At some point I'm just going to get something else. Its literally driving me crazy. Its a shame too because otherwise I really like the vehicle.
WingsAA
CMFIC
Dallas, TX
I've given up on mine. Had it in several times to the dealer as well to no avail. I have secured the seat belt adjuster mechanism as well with felt tape as well as every other imaginable piece.
Can you test something? Reattach the pillar and don't tighten the two bolts in the grab handle... or leave them out. When I did this the noise never occurs. Also, the only time I ever hear the noise is after the vehicle has sat in the heat for some time... like sitting at the office all day in the heat. When I'd leave to drive home it would rattle and drive me crazy.
I almost think it's the inside of the rubber door seal trim "itching" on the interior pillar trim piece.
Tahoe14
Central Fl
Could you drive it with the trim panel off and have someone ride with you and try to pin point the noise?
WingsAA
CMFIC
Dallas, TX
Both the dealer and I can hear it and it's clearly coming from the pillar area just behind where the belt adjuster is. If you reach back and pull on the grab handle it stops. The dealer has even replaced the pillar trim. It happens on both driver and passenger sides... only when it's hot outside and been sitting in the heat. That's what's leading me to believe it's somethimg with how the pillar trim rests on the inside of the door seal surround.
Here's a video of the rattle/ticking...
https://goo.gl/photos/K5BCTsSXvDbgpV7F6
DWTahoe
DWTahoe
Colorado
I was just in there yesterday too. Mine was definitely the seat belt guide with the cheap plastic push clip. I didn't pull the whole b-pillar off, so i just insulated the bracket. If it starts making noise again I'll have to pull the whole thing and bolt that piece in place. The sound from that clip usually sounds like metal on metal, anything else is probably what others describe with the outside trim or something else.
WingsAA
CMFIC
Dallas, TX
I agree... thought it was metal as well and thought that seat belt guide was the culprit. There's literally nothing else to check. But again... I have the two bolts in the handle loosened and I don't have the rattle anymore.
6point2lovelifers
