my 2004 yukon xl is needing a new stance
bassgas
bassgas
Dreaded state of Illinois
Going to clean all the underside and spray it with some undercoating. After removing the running boards you can see the under frame. Maybe do something to the brakes as well.
bassgas
bassgas
Anyone have any suggestions on what color to paint calipers and I do not want red. Not sure what would look okay on it. Thinking Black may be only one that will work with my Kon
bassgas
bassgas
Put in spring spacer only got 1 " of lift in the rear [emoji107][emoji35]I thought it was going to give me around 2" guess I am going to do something different. I measured from under the wheel wells and have 36" under the front had 36"1/2" under the back added spacer now ha e 37 1/2" after adding 2" spacers maybe I put them in wrong place or I need new springs. aa773df382d965442d5f6f50c54976a3.jpg
TXBowtieGuy
Earth
I put 3 inch coil spring spacers on mine. You can also get z71 coils.
TM98
What rear shocks did you have bassgas?
