New headlights installed.
chevrol8t
chevrol8t
Gents I think it's time for me to buy new pigtails for my lights. As I was rotating the connectors (both signal and DRL) to get them out my headlights, those connectors started to disintegrate right in my hands. They did feel a bit brittle when I pulled them out the original housing but this time they are literally falling apart when I went to pull them out the new housing. On both sides at that. The passenger side DRL was so bad that there is a little bit of metal contacts for the bulb now exposed. I guess after 16 years in the AZ heat they finally had it. I also discovered some burn marks on the passenger side DRL connector as well. Not saying this is without a doubt what may be causing my issue but I think I will replace ALL pigtails then try troubleshooting again.
pt1965
columbia,sc
Looks good. I got the Depo headlights and did the ping pong ball mod to keep them from bouncing around. The brackets were a bit softer compared to OEM, so in the end I swapped out the OEM brackets onto the Depo headlights and they fit much tighter.
WHAT IS THE "PING PONG BALL MOD"??
Fosscore
@pt1965
When you have your new Depo headlights installed, you insert one or two ping pong balls in between the actual light and the frame to keep them from wobbling. Some guys have no issues. Mine tended to wobble so I put 2 balls in there to stabilize the lights.
It is a bit ghetto, but it works and nobody can see it. I then decided to swap out the Depo brackets to OEM brackets to stiffen up the lights which worked better.
Check out this thread.
http://www.tahoeyukonforum.com/threads/depo-projectors.12304/
chevrol8t
chevrol8t
@pt1965
Had no issue with my headlights, my replacement fog lights on the other hand act like they are sitting on the San Andres fault line! :)
Fosscore
That is an known issue and OEM fault with the brackets and mounting position down there. Some guys bracket them up tighter, change them out for more sturdy LEDs or pod LEDS. I don't run them that often to warrant the change, but the Depos needed attention. Again every truck seems to have a mind of its own...you know? lol
chevrol8t
chevrol8t
Truth! Sometimes our rides are great and other times it needs an exorcism! :)
BeenChevy
Minnesota
Chevrol8,
Looked into similar parking lights when they first came out until seeing others who had them told me the LED's start go quickly. 1 guy had 7 out in less than 6 months.
Most recent spyder assy I own came in Spyder marked packaging with quality projectors and use stock bulb size.
Get your $ back. I dig LED markers. Hopefully yours include Spyders craftsmanship warranty
chevrol8t
chevrol8t
Chevrol8,
Yeah been going through email with carID. It's without a doubt their lights that is giving me fits. It's popping the parking light fuse. I was asked to rotate them (the connectors 180 degrees) which solved the issue of the fuse popping but I still have not parking lights.
When I plug my old bulbs in I have no issues. When I plug the new lights in...POP! There goes another fuse.
Waiting to hear back from them...
chevrol8t
chevrol8t
First thing I want to clear up some issues with my statement about the problems that I was having as I did not properly explain it which I apologize.
1. Minus the parking lights. Everything else works (signal, flashers, corner lights (flashing) and DRL). So yes, it's my parking lights that does not work. I went back through some of my statements and realize I might have been causing some confusion.
2. Yes I was popping my parking light fuse. At first I thought the fuse was fine but after looking at those tiny fuse closely it was popped for the parking lights.
3. I contacted CarID (still talking to them) and they stated that I should rotate the connector 180 degrees (as fosscore and 05Single suggested). Well the good news is that I no longer pop the parking light fuse but not only did the lights still not work but it blew out the fuse for the signal light.
I would like to try a load resister but I was informed that those were not good for parking lights as they will get very hot for being on for so long instead of on/off if used for as a signal light.
Still waiting on CarID to get back with me.
BeenChevy
Minnesota
Well i still like the idea of the LED parking lights despite the others I've seen who are missing LED's after a short time.
What if you run the parking lights to a relay and then to your batt direct and then ground each light securely to the frame? I think this may help if not eliminate the fuse issue as your fuse would then be before the new relay. You could test again the LED polarity connecting straight to 12v
Something is obviously wrong with either your new lights or your wiring. I wouldn't add any relay or modify your stock wiring, but do fix your sockets if they're bad. And no don't add a load resistor to the park light circuit, it will just blow the fuse faster since it adds a load to make up for a LED which has little resistance. So fix your wiring and if there's still a problem, it's your new lights.
chevrol8t
chevrol8t
Leaning heavily to my new lights. I can plug my OEM lights back in the sockets and they work just perfectly. As soon as I plug the new lights in...POP!
If it was me, I'd return those to CARiD. I hate that company anyway though, they took my money once for something they say they had in stock, then it took 2 months to get it back when they couldn't deliver. Dishonest mofo's if you ask me. I'll NEVER buy from them again. I wouldn't believe a damn thing they say. Good luck.
MoundMedic7
