Blue gauges and HVAC
JKmotorsports
Austin, TX
Guess I'll start the Interior topic off.
Here are some pics of my recent blue LED mod:
05Yukon
Houston
Looks good but are they hard to read some of them look really bright.
Shaggy
Admin/Owner
Arizona
Yea, hows the look of them at night well you are driving? Is it to much blue?
PavementPounder
Cincinnati
How did you get the volt meter to light up so well, mines kinda dim and the bulb does'nt fit directly over it like the rest of the guages?
oneradride
Omaha, NE
I did this also.. and was thinking the same thing... ??
JKmotorsports
JKmotorsports
Austin, TX
The LEDs aren't as bright as they look in the pictures. I took the pictures in almost complete darkness in my garage. I left the shutter open on my dslr a little longer to take in all the available light to get the pics to come out the way they did.
JKmotorsports
JKmotorsports
Austin, TX
I didn't have a problem with mine. Seems like mine lights up evenly across the entire cluster. The only dim spots are on the HVAC panel, but I've already got a plan on how I'm going to fix that.
TheFuzz
Idiot Police
Spurbury, VT
Hot damn JK, that looks awesome! Where did you get all of the LEDs? The dimmer and everything still works, right?
JKmotorsports
JKmotorsports
Austin, TX
Thanks guys.
I got the LEDs for the gauges from ledlight.com. The LEDs for the HVAC are single units I had laying around and soldered them to the board with 500 ohm resistors.
The stock dimmer won't dim the LEDs. The dimmer adjusts voltage to incadescent bulbs to change to brightness. To dim LEDs, you need to decrease the forward current. The best way to change the intensity of LEDs is by PWM (Pulse Width Modulation) and changing the duty cycle of the LED.
Shaggy
Admin/Owner
Arizona
Thanks guys.
That sucks. That makes it difficult to use when you want to try to dim them.
JKmotorsports
JKmotorsports
Austin, TX
If you don't usually bother with the dimmer control, it's not a big deal. The LEDs aren't bright enough to distract you at night.
tybardy
everyone needs a Hoe
Gilbert Arizona
anyone ever put the LEDs in ALL the interior lights? like the overhead lights and stuff? I have seen this done and took a looksy at my head liner and i cant even figure out how the hell to access my bulbs in those things
JKmotorsports
JKmotorsports
Austin, TX
Like this?
On the lens there will be a small notch where you can use a flathead screwdriver to pry the lens off. Once off, you'll have access to the bulbs and you can just pop em right out. I replaced all the bulbs in the interior (doors, footwells, etc) and the puddle lamps. I also wired the interior domes so that all three bulbs come on, not just the one in the middle. I added a dome light assembly to the liftgate also:
Rivieraracing
That's pretty sweet, especially the lift gate light!! What type of light did you use for the lift gate light?
JKmotorsports
JKmotorsports
Austin, TX
It's a stock assembly from another truck. I had a few of these laying around leftover from overhead monitor installs.
moto
