wth is the speed sensor?
johnnunez29
i got a erratic reading on my denali and im getting conflicting info on the location. and the cause if anyone knows please pass on the info thanks
Gzes
the drifting 2dr
Wichita tx
Speed sensor is usually in front of trans or on trans and reads how fast the gears are spinning causing everything to function as it should
Sasquatch
Orange County N.Y.
The wheel speed sensor is in the hub bearing. To replace it you need to replace the bearing. I just replaced one on my yukon, It took about an hour and $180 for the bearing.
J
johnnunez29
would this be the part that throws the code reading "right front speed sensor erratic?"
Sasquatch
Orange County N.Y.
I replaced my bearing because it was making noise. It wasn`t throwing a code or any message so i`m not sure but i can`t think of anything else it could be.
There is a sensor on each wheel so the fact that it`s telling you about the right front tells me that it`s the hub bearing.
I`d take it to auto zone or an advance auto parts store and have the truck scanned to pinpoint the problem.
J
johnnunez29
may very well be. i was getting a code thrown for the 02 sensor and the car was misfiring on idle. i changed the spark plugs (it had double platinum lpugs from autolite even though car requires iridium) ,cables and the 02 sensor. car no longer misfires and they scanned it but only got the 02 sensor code this time. he cleared it and it hasnt come back on yet. though now when i turn the wheel seems to slide and occasionally when i brake it slips and abs lights up
CTown LTZ
Cleveland, OH
Wheel bearing failure. ABS code is the final factor. The speed sensor inside the hub assembly fails. When this happens the ABS sees this as a wheel spinning at a speed different from the other wheels and activates the ABS system. If it's not happening yet, your ABS system may start applying the brakes to those other wheels making it difficult to accelerate from a stop. Pretty common failure.
bret04yuk
Minnesota
CTown LTZ is exactly right! Mine had the problem for two years before I dug into it and saw how easy it was to fix. Gets really annoying at a stop light or stop sign, accelerating, then having the ABS kick in, kill the engine RPMs, take your foot off the gas wait a moment then accelerate normally. (Every single flipping acceleration!)
Lighterknot
