Won't move and brake light on
tyrone27
I have a 93 suburban and I heard something pop now the truck won't move and the emergency brake light is on. I can put it in reverse and drive and each gear but nothing. It's like the transmission won't engage.
Sent from my SM-N910T using Tapatalk
mtl111
Arkansas
You say there was a pop and the emergency brake light is on...can you apply and release the emergency brake? Sounds like something " like a spring" came loose or broke. Pull the brake drums and check things out.
Sent from my SAMSUNG-SM-G930A using Tapatalk
revolt
Hope that is just minor like loosen or broken spring that makes the emergency brake engage.
T
tyrone27
No the emergency brake is fine just the light came on and won't go off when I was raving the motor. It was never applied. But the transmission won't engage into drive to move.
mtl111
Arkansas
Try pulling out on the emergency brake release and hold it out while pulling up on the e brake lever with your other hand and see if the light goes out. If not, it may need some adjusting or you have issues at the rear. As for the trans not engaging...do you " feel " it engage each gear when you move the gear shift, or is it just a smooth movement...not feeling each notch for the gears?
T
tyrone27
The shift handle feels normal but it doesn't engage any gear in the transmission. I noticed the I had a exhaust leak when I brought it but it's been reported. But I was looking under the left side and saw the plastic loom was melted but the wires look ok.
mtl111
Arkansas
I was curious if there might be an issue with the shifter linkage, thats why i asked. I would just inspect the e brake, shift linkage etc.
T
tyrone27
Everything looks good so I'm thinking it's a wiring problem so going to have to tow it to a shop
T
tyrone27
It's the transmission. Previous owner lied. It was never rebuilt and the pump went up
mtl111
Arkansas
That sucks man, sorry to hear that.
Milano_II
