Whipple is installed
Fifty
I think I found it. It was cutting the fender wall of the intake box right?
NGAneer
NWGA
Yes. There is a plastic brace that runs diagonally across the "mouth" of the intake box. I cut that out and the corresponding metal on the inner fender.
Fifty
How accurate is the dashlogic with boost?
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
so far, it has been very accurate for me. i have 3 bar sensor installed.
gat0r is correct. The OEM MAP doesn’t read higher than 2psi. I too have GM’s 3 bar sensor but it can’t be installed until the tuning is done. The boost reading without an additional gauge/mount/etc. is the main reason for my buying this DashLogic/AutoMeter DL1061U.
Fifty
So the dashlogic will read correct with the 3bar and the whipple canned tune?
Does the whipple kit come with the 3 bar map sensor?
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
Whipple’s tune requires the factory installed MAP be re-used, unfortunately. Upgrading to GM’s 3 bar MAP requires a re-tune.
zachattack_0924
