Wheel nuts
greenhornet
Ontario,Canada
I have a 2015 Tahoe LS with 18" factory mags.,The original nuts are 60 deg. conical nuts with the sheet metal overlay which are splitting. So i would like to replace them with chrome or stainless replacements.Many listings indicate that 60 Deg. won't fit my wheels,so my question is what are the correct type for the factory wheels? I have measured the factory ones and they are 60 Deg. conical taper.Thanks.
Tahoe14
Central Fl
Contact your local dealer, give them your VIN and ask the part # for lug nuts. Then you know for sure instead of guessing.
G
greenhornet
Ontario,Canada
I have the original nuts but when i but tires and rims foe snows (steel rims) they said i needed different nuts so i got them and they turned out to be the same as factory mag wheel nuts. I looked up options on Amazon and many say will not fit a 2015 Tahoe even though they are the same physical dimensions.Just curious why the discrepancy.
kootamcgrabbin24
