Weird electrical issue...alternator?
PG01
Up here to the right
Very easy, unbolt from battery follow cable to where it goes and unbolt it there. Take to auto parts store and get same length.
George Owens
George Owens
From what I hear this one Cable has three different points to where it’s grounded and supposedly it has a sensor
George Owens
George Owens
Quick update took the battery to AutoZone and it tested good at 94% have to take the alternator and put it back on the car because that’s the only way they can test it
George Owens
George Owens
OK before I put the battery and alternator back on I scrub them clean with wire brush, I scrub the terminals and I scrub the battery post. I also scrubbed the post and terminals that connect to make a fuse. Went to AutoZone and the alternator tested good. So I’m a little bit stumped trying to see if I can make the issue happen again currently
kbuskill
NE. FL.
Internally corroded battery cables are the culprit more often then not.
George Owens
George Owens
I hear that a lot especially the negative ones, I’m gonna look into ordering one, the dealership wants 170 for one
George Owens
George Owens
Plug the part # you got into google I guarantee youll find it cheaper..try amazon 1st
Got it for 48 bucks rockauto, now I’m tryna find out how to install i seethe 2nd ground but the 3rd seems to be under the coolant hose might give me problems
Brian12019
