Washer fluid tank leak
95escahoe
Today I noticed when I used my windshield washers there was a puddle under where the tank is and some fluid over the engine compartment never any leak besides when I use them had a similar issue on my OBS Tahoe ended up being the pump, anyone ever have this issue if so was it the pump?
MrBalll
West Texas
If it's in the engine compartment I would check your plastic lines. Have someone press the button and just look at were it's coming from. Very brittle lines with age and probably cracked. I had one crack just above the battery. Went cheap and just taped it.
95escahoe
95escahoe
That would make sense cause it was on the battery and could have easily leaked down ill try that out and see
Danny3737
I had the same thing happen last year. Mine was a cracked washer pump. Pretty easy to replace
I had a similar issue. The connection under the hood separated that led to the rear washer pump. Connected it and all was good. Does your rear washer pump fluid?
seeker
