I just bought a 2001 Yukon Denali and have had two issues come up that I would like some thoughts on. The first issue is that when I start the Yukon it will sound like it is cranking then grind the starter. On the second attempt it starts right up. When I have driven it for a period of time it will usually start on the first crank but I still get the starter grind sound. The sound is similar to that if an engine is running and you turn the key. Is this an issue with the starter not disengaging quickly enough?
Second issue is that from time to time I will get my brake light and ABS light to both pop on and stay on until I turn off the engine. Brakes work just fine. Was told be previous owner that he recently replaced a brake line. I have taken Yukon to various auto parts stores when lights are on and told that they cannot run codes to see what it going on.
Any thoughts would be appreciated.
Thanks!
Thanks!
