Traction control?
BillBlatt18
Latham, NY
This happens whenever I start up my truck in the morning and back down the drive way and then put it in to drive. The truck slows and makes a sound like the gears are slipping or like it's not in gear. When this happens, I get the message "Traction Control Active" on the dash screen behind the steering wheel. Any ideas?
Sasquatch
Orange County N.Y.
I had a similar problem on my yukon, when i took off from a stop i would get the traction active light too. it was a faulty speed sensor in the front hub. the computer was getting a false reading and it would activate the traction control.
BillBlatt18
BillBlatt18
Latham, NY
I'm bringin the truck in to my local goldstein gmc to get some other things fixed, I will suggest this. Thanks sasquach!
stscott
I have a 05 Tahoe, last week I was at a light and when I drove off and got to 20mph my Tahoe made a grinding noise and the Traction Control Light came on. I can drive 5 mph but after that the grinding noise, The next day I had a buddy who works on trans and when he and I drove the Tahoe no problems and no Traction Control Light ???? The Tahoe acts like nothing happen ?? I drove it like a Vette. What can cause this to come and go ??
ktmhans
Connecticut
Do a search in the tech forum i believe, ya gotta pull the caliper, pull the rotor. Expose the abs sensor. Remove sensor, sand down the hub where the sensor bolts in. Paint area, i used battery terminal paint. And reinstall. The sensor is no.longer making contact with hub because of curosion. Solved my problem. I couldnt roll a stop sign. I or pull into a parking spot slow with out it kicking in.
dbooksta
I'm having the same problem on a 2004 Yukon: At speeds below 20mph, light acceleration will occasionally produce the "Traction Active" dash notice and briefly brake and/or reduce power. I haven't had it happen with stability control system shut off.
Any tricks to figure out which wheel's sensor is bad?
BTW, this appears to be the thread on replacing a sensor.
Sir Lapalot
Ontario, Canada
Temporary fix: disable the traction control (by hitting the trac ctrl button) till it's fixed.
bit of a pain to remember to do EVERY TIME you drive it, but better than the alternative
Laurents10
