94z71yuk
- Joined
- Jul 13, 2012
- Posts
- 9
- Reaction score
- 0
okay so i blew a head gasket so now is a good time to just rebuild the entire top end minus the rotating assembly. im not good at spelling and nor am i a master mechanic. i started this project with out thinking of taking pictures for other users but.
http://www.tahoeyukonforum.com/forum/attachment.php?attachmentid=16941&stc=1&d=1342375417
i will start now i started by removing the alternator then the ac bracket and idler and tensioner pulleys then the pewer stering pump which mine had me stumped. i can fit a 3/8 allem key so i figured it was held on by a bolt and my dumb self didnt refer to the hyanes manuel till i got frustrated. its pressed on for future refernce. another note is you do NOT haft to take the bolts out of the ac compressorjust take the whole bracket off much easier. after the power stering pump i removed the wather pump i just left the fan and pully all attached just to get it out of my way then i unpluged the harnes disconected the fuel lines and removed the throttle body.
http://www.tahoeyukonforum.com/forum/attachment.php?attachmentid=16942&stc=1&d=1342375417
after i removed the ignition coil and throttle cable bracket on the intake and thats where im currently at i'm removing the heades and having them resurfaced so any tips from someone who has done this or an experianced mechanic will be greatly appreciated.
http://www.tahoeyukonforum.com/forum/attachment.php?attachmentid=16943&stc=1&d=1342375417
okay so i went out and removed the dizzy. failery simple after you mark the dizzy and rotary button remove the hold down bolt (i just losened) just gently pull and wiggle till it comes up.
http://www.tahoeyukonforum.com/forum/attachment.php?attachmentid=16944&stc=1&d=1342375417
then i removed the intake. to remove i refered to my repair manual and it showed a diagram of which order to tighted the bolts back down and it said to remove reverse order. so i followed the instructions only turning the bolts 1/4 turn untill all pressure was off the intake manifold then i removed it. also sunlitcomet this is the picture of that block off plate i found could you explain to me what its for?
http://www.tahoeyukonforum.com/forum/attachment.php?attachmentid=16965&stc=1&d=1342376193
