Tire/rim combo on 02 suburban
02burban
Hey guys I'm new to here. I'm trying to find some new tires and rims for 02 suburban 1500 4x4. What size rim and tires will fit without having to shave fender or without lifting? Also what offset would make tires stick out just a little? I am also debating on lifting it. What lift is best for around 3 inches? Torsion key and blocks of full suspension? Thanks for your help
Welcome to the Forum from NH.
Lots of great folks here who freely share their knowledge, experiences, and perspectives.
For starters, you can use the web URL below to start benchmarking your current stock rim/tire specifications and critical clearances, by plugging in your current rim/tire size and measuring and entering the existing clearances for the critical fender and suspension components. Then, you can model other rim/tire combinations, and see the changes in clearances.
https://www.wheel-size.com/calc/
This will get you started, and then other folks will chime in on their actual experiences with their own rim/tire mods.
NPKennny
