Suspension lift, torsion adjustment and alignment
ZapataUSMC
I just installed a supreme suspensions 3” suspension lift. After installing, all measurements were somehow spot on and level all the way around. Installed Rancho 7371 shocks and now my levels are off by 3/8” in the front(I need to bring front end up to match rear.) I already had an alignment done(twice on the past month. I replaced ball joint, tie rods and sway bar end links). Will cranking the torsion keys up 3/8”(3 full turns of torsion key adjustment bolts) throw my front end off that bad? Trying to avoid getting another alognment( I know the guys at the shop are tired of seeing me there, haha). Below are my alignment results:
Caster:
Left - 2.0 degreees
Right - 2.8
Camber:
Left - 0.2
Right - 0.7
Toe:
Left - 0.05
Right: 0.05
Total - 0.10
Rear
Camber:
Left -0.6
Right -0.7
Toe:
Left -0.10
Right -0.10
Sorry I’m not alignment savvy. Any advice suggestions are greatly appreciated!
John Root
Thanks a ton for attached pick and details and measurement. it will help me a lot :)
BWASTEEZE
