Small Screen - no BT
Someone
Kingdom of Saudi Arabia
Hey there,,,,
Tahoe 2015 LS (Basic) 2x4
The screen is small (4")
There is no Blue Tooth (although the buttons & mic are available)
A. Is it possible to upgrade software to enable bluetooth. / or it requires hardware (of some kind) also.
B. Is it possible to change the small screen to the big one. (after market or original)
(HOW) !!!!!
JohnC12
Orlando, FL
Hey there,,,,
(HOW) !!!!!
A. - No, it's not possible.
B. - Which radio do you have? IO3 or IO4? (Check out post link from NathanJax to find where to look) If you have an IO3, it's not possible to upgrade to the 8" OEM system. If you have the IO4, yes you can upgrade to the IO5 or IO6 OEM system. The upgrade will run you between $800 and $1,000 + installation. And yes, you can change to an aftermarket setup all day long.
In addition to the link provided by NathanJax, here's a thread with an aftermarket How-To. Good luck!
http://www.tahoeyukonforum.com/threads/aftermarket-radio-installation-2015-tahoe-ls-with-io3.76779/
Someone
Someone
IO3.....
so I guess, I have to live with the small 4" screen...
Thanks anyway....
If anyone finds a ways to upgrade IO3,,, let me know...
ccbaugh
