should there be any lateral play in the front wheel of a 2010 yukon
black2010slt
Been hearing a front end clunking noise since 20,000 miles had it the dealerships at least three tines being checked when oil changes being done. Always checks out. Today I had to drive through a field and it Sounded like a truck built in the 70's. When I got home I rocked all the wheels laterally and the front left wheel was clunking pretty good. From my experience with ATVs It would usually be the ball joints or wheel bearings. Couldn't see any play in the ball joints and it seemed like wheel bearings. I would think there should be no play. Correct?
NASTY GM
Nor Cal
There shouldn't be any play. Have you done any suspension mods?
Pooter
DFW, TX
Did you get it aligned after the leveling kit?(just if there might be a loose bolt or something by accident)
Do you have anyone that can move the wheel while you check from the backside?
Thekenstar
