Service ride control messege??
Wake
Stafford, VA
Could be several things. Each shock is connected to the ride computer along with the air compressor in the rear. You need to scan the body codes to determine what is causing your message.
My Escalade had two problems this year, one the left front shock connector was destroyed by years of salt intrusion, then the exhaust solenoid for the air compresson.
chacho44
chacho44
MOTORCITY
Ill start with the connections on the shocks. Maybe try to clean them up a bit, but i also forgot to adress that my compressor does not kick on. This has been like this for a while just never adressed it cause truck still rode fine.
einzunza
Mine has been saying the same things since I replaced my shocks. I had Monroes installed and I've been getting the same message, anyone have an idea on what it could be?
bl74
