Recommended head gasket kit?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
use the fel pro hst7733pt16 kit the Perma Torque Severe Duty one. better head and intake gaskets and valve seals.
also replace the original efi design with a new Delphi FJ10566 Fuel Injector SCPI to MFI Conversion Assembly
you will also need two of these head bolt sets Fel-Pro ES72856 Misc Set and one set of Fel-Pro ES72224 Engine Intake Manifold Bolt Set
inspect and if needed replace your dizzy gear. have your heads inspected as well as definitely get your intake manifold cleaned and blasted at a machine shop it is going to be dirty when you see it.
if there are no defects with the cast parts and everything is assembled properly you will not have any issues at all with leaks.
W
willxfs
Thanks for the information Sunlit. Almost forgot about the new bolts. Definitely need those. Already have a new spider injector set so I'm good there.
I would like to clean up the bolt holes for the heads bolts. Anyone know what size thread chaser tool I need. Thanks
SunlitComet
OBS Jedi-Do Good
7/16-14 for head bolts
---------- Post added at 02:34 PM ---------- Previous post was at 02:33 PM ----------
5/16-18 for the intake mani bolts on the side of heads.
SunlitComet
OBS Jedi-Do Good
uh yeah, not needed for the application use here. we are not at the track on a continuous basis to justify it. besides the printoseal has fantastic sealing abilities and cylinder armor is more then enough for some great modding of engine for power.
gradymossx4
