electro
Hi guys, it's 9pm and I just realized my rear hatch it stuck in unlocked position, well it was but than I used a small slot and closed the locks and now my hatch won't seal.
Lock mechanism? I'm getting out the Haynes as I type this and I'm going to remove rear plastic covering from hatch.
I just need to lock this baby up for the night. All me tools are inside the truck.
Any quick fixes?
I've never had to deal with the locks before.
Thanks,
Ryan
---------- Post added at 09:40 PM ---------- Previous post was at 09:07 PM ----------
Update:
I removed trim panels.
When I press unlock / lock, my mechanism moves but the latches to do not.
---------- Post added at 09:42 PM ---------- Previous post was at 09:40 PM ----------
---------- Post added at 09:55 PM ---------- Previous post was at 09:42 PM ----------
The actuator moves.
The push release for the glass was loose from its position
I think there's a spring return in the push button release that is not pulling the inner shaft back.
---------- Post added at 10:01 PM ---------- Previous post was at 09:55 PM ----------
So, the actuator moves on command (ie. when I press lock/unlock).
IT WOULD THE ISSUE IS WITH THE PUSH BUTTON RELEASE FOR THE GLASS HATCH.
In the below picture, the push button release is in the returned position.
In the below picture the push button release is not returning. As if internally the "spring return" is damaged.
Any quick fixes?
Thanks,
Ryan
Update:
The actuator moves.
