seadaddy
I have a 95 2 door yukon that seems to be leaking from the drain petcock on the radiator. I replaced the petcock this weekend when I did a coolant flush, there seems to be quite a bit of play in the plug. The old and new one leaks. Is there any way to seal the drain for good with a bolt? I feel as though the plug is very weak and prone to failure.
Thanks for any insight!
