Question about antifreeze
ccapehartusarmyINF.(ret)
Gilbert AZ
i totally agree with u i do not like "bandaid" or temp fixes or treating symptoms
just knowing there is a root issues that isnt being addressed just annoys the crap out of me its even worse is when i dont have money to fix something like my god dam window regulator that broke again
mtocrs1
30k miles seems permanent enough for me but to each their own I guess. I am usually the same way GM radiator seal tabs have never done me wrong.
Only use the GM ones. Remember GM puts them in all their cooling systems from the factory. Or at least they used to. Can't be 100% sure they still do.
Tahoe0159
Hope the OP finds the problem. I am tracking down something similar in our '01 Tahoe.
It is important to find and fix the leak. Main thing I was worried about was the "leaking cylinder head" issue, but found out we don't have the "bad heads" so that worry is less.
Since it's 100+ degrees (heat index) right now and I don't have an AConditioned work area, I am thinking about putting my full repair off until Fall.
Was this the coolant tablets that were discussed earlier?
http://http://www.amazon.com/Genuine-3634621-Cooling-System-Tablet/dp/B000QIH3C4
Might be a "temporary" fix until cooler weather.
mtocrs1
Yes those are the ones I used.
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Just pressure test the cooling system with a pressure tester. Pump it up to 15 psi. Look to see if it holds the pressure or if it slowly drops off. If it drops off, pump it back up and look for leaks. First thing I do is drop to the floor and look for a dripping coolant if it's not obvios from above.
SLCHOE
Midvale, Utah
On the pressure test, where is the best place to get the test equipment?
(not trying to jack the thread, but it might be helpful for the OP to know)
EDIT: WAIT Nevermind...I missed this post earlier. :emotions122:
http://www.autozone.com/test-scan-and-specialty-tools/cooling-system-test-kit?CJPID=3484884&cmpid=cj
http://www.amazon.com/Stant-12270-C...sbs_263_2?ie=UTF8&refRID=1S25G87QRGZ1NRWFRFS4
http://www.amazon.com/Stant-12026-Radiator-Adapter-Vehicles/dp/B000VSFIWQ/ref=pd_bxgy_263_img_y
Both for about $107
fishcop076
