Picked up my Yukon Denali Xl
Bigbird
Schenectady NY
Picked it up Friday drove home Parked it put some stuff from the old one in it
Went to start it turned over but nothing happened no pop spit or anything.
Went into the house for 15 minutes came out tried again started right up but lots of
messages which finished with it going into to limp home mode.
Got up this morning hoped it would start Fired right up ran great but check engine light
was on
Got to work and called the dealer and brought it in They put it on the machine and found the
check engine light had gone out because the problem had cleared itself
They went back and found the codes that showed the problem and the way they explained it
to me was the high pressure fuel pump must have had some type of blockage that cleared itself
and that's why it wouldn't start Once it cleared out the blockage all was good
Drove around for an hour all went well
It's a gas 6.2
I had a 2018 before and this is a whole new ride Very comfortable!!!
I'll post pictures as soon as it warms up enough to stand outside
Miami-Dade
Super Moderator
Congrats Brian!
Hope all goes well for you here on in with your Denali XL!
Fireman591
Michigan
YIKES!!!!! I hope all goes well for you. The fuel delivery issue took mine out of service for 30+ days. I have the 5.3 V8. Keep us posted.
Bigbird
Bigbird
Schenectady NY
Here is the story of my problem
Results of scan at dealer
P228 D Fuel Pressure Regulator Performance
P0089 Fuel Pressure Regulator Performance
They could not duplicate it and it has run great ever since
Got 250 miles on it now no other problems runs geat
Big Mama
Virginia
Pics? It’s not that cold man....
I’ve got a friend in your town. He owns the Albany Patroons. Great guy.
ynot411
