p306 misfire questions
97blueyuk
Okay so after changing my o2 sensor my cyl 6misfire is back. Ive replaced plugs,wires,and cap. Tomorrow I am pulling the plug and replacing currently using autolites until I get the bugs worked out. What else could be my issue here. What tests should I run or have someone run if the plug isnt the cause?
Thanks for all your help with this truck so far
JKmotorsports
Austin, TX
Did you check the fuel injector to make sure it is operating properly, not clogged, etc?
97blueyuk
97blueyuk
Actually no i didnt. Didnt even think of it. Will add that to list thanks
kevinsbritton
