Oil filler tube leaking at valve cover.
99Vortec
Before I pull the valve cover, is this serviceable? Is there a tightening mechanism/gasket, or is the filler tube integrated into the valve cover?
Thank's.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i believe it was screwed in placed by an assembly machine of course so it will take some effort to get it off to replace the o-ring on it.
BirchyBoy
Or remove it and put the fill cap directly in the valve cover. That's what I did.
99Vortec
99Vortec
Thanks for the input. I got a left bank rear heated 02 sensor error surfacing at times.
Well at least both problems are on the same side of the motor...:D
SDHanz
