Maw7989
Thinking about replacing the o2 sensors on my 2009 yukon 5.3. It just turned over 130k and figured it probably wouldn't be a bad time to change them. What brand do you guys recommend?
How do you tell if they're getting lazy?This is what I'm replacing mine with next week:
https://www.amazon.com/dp/B0010GHAI...olid=3MYY1OQK1UL4M&psc=0&ref_=lv_ov_lig_dp_it
Just doing the upstream sensors. One has gone lazy at 135K.
These are the downstream sensors that measure the health of the cats:
https://www.amazon.com/dp/B0016IGZ1...olid=3MYY1OQK1UL4M&psc=0&ref_=lv_ov_lig_dp_it
Thanks, I may try to watch the upstream sensor voltages on my Torque Pro app to see how my sensors ars doing.I watch it with the scan tool. The upstream sensors are supposed to cycle between 50-900 mv and as of late are rarely passing the 700s and instead of going all the way down, sometimes hang in the 300s for a moment before cycling properly again. One is worse then the other. They were just fine 3 months ago. Still not bad enough to throw a code and mileage does not appear to be suffering though I've switched fuels again trying out this E30.
The Tech-2 also allows you to run a graph but the problem with these is easy enough to see by the numbers.
My 2012 runs fine, but since it's new to me and I got it with 100k miles on it (currently has 105600) I don't know if they've been replaced.
