Norcal's 4x4 w/autoride 2/4" drop kit
2016YUKONSLT
Put kit of yesterday.
Front dropped from 35 11/16" to 33 3/4" I had 21,*** miles on previous tire and put new wheels/tires on at the same time.
For the rear: 37 5/8" to 35 1/4" drop. I used the hose on top instead of spacer, but used spacer on bottom instead of hose. Tony suggests removing spacer and replacing with hose and getting a new adjustment bolt for autoride.
24" Dub Futures with Lexani tires
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
1) cut bracket off
2) remove spacer
3) make rear like 2.5 inches like we spoke about
will bring back the rear lower and look way better. I sent the links via usps mail should of been there for sure. if not I can send you another set
using the spacer and the autoride link thats in there now is lifting the rear up so has that rake. The kit can come down to 33 7/8 inches on that tire
2016YUKONSLT
2016YUKONSLT
You mailed the links? You shouldn't have! That spacer is so thin, I'm surprised it makes much of a difference compared to the hose.
Drivers side front tire rubs on sharp left turns. Any recommendations to fix?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
the rear spacer is 1 inch if we are talking abotu the same thing. the upper insulator is almost 1 inch while the heater hose is like 1/8 once weight on it.
you will need my fenderwell mod. PM me ill tell you more
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
If he wants to being rear down to match front I highly recommend it.
2016YUKONSLT
2016YUKONSLT
Looks good. Did you do the free travel mod? I need to order that for mine
Not yet. I just bought some new air tools to try to make it easier. When I get back under it to do the rear drop, I will try to remove it.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
12 inch sawzall blade.. makes it way easy
Codered5557
