ScottyBoy
Alarm has NOTHING to do with the radio. If you try to say the alarm installers messed up your radio, you will be wasting your time and theirs.
I would start with the speakers. They are 11 years old and most likely rotted out. If you continue to have problems with the sound cutting out, then you may have a short in the actual speak wiring. The most common place would be where it runs thru the rubber boot in the drivers door jab to get to the door. Constant opening and closing of the door over the years can flex the wiring to the point that they can and do sometimes break. I had one of the wires for my power lock do that. It was an easy fix once I located where he problem was in the wire.
