Joshuasvt
I had a bad wheel bearing, so today I replaced the front left hub assembly with a MOOG 515036.
Also changed brake pads and rotors on both sides.
I put everything back together and bled the front brakes, but now I'm getting ABS, Parking Brake light and a "Service Brake System" message. My BlueDriver says it's the front left ABS something, but then it disappeared, so I don't remember the code exactly.
What should I do from here?
Is this something dumb like I only replaced one hub assy so the module thinks the other one is bad?
Or I didn't bleed the brakes properly?
I didn't kink any wires, but I'm pulling the wheel off again tomorrow to double check the harness.
Any advise would be helpful guys. If I cannot figure it out, it's going to the mechanic.
