OK so I bout this 07 Yukon used and some one added the OEM navigation system to it before we bout it.
It works but has 2 problems.
First it will not give you voice guidance. (Yes it's turned on in the settings. Yes the volume is turned up.)
Secondly it will not reroute if you miss a turn, or are unable to follow it's routing for some reason.
Next I want to add a backup camera but have been told that I can not use the normal GM kit do to the truck not having navigation from the factory. What do I need?
And lastly I want to add a sub amp to the system. I already have the factory Bose sub, but it's kind of weak, and I already have an amp and subs that I would like to install.
I am open to replacing the stock navigation system, but I don't want to lose my steering wheel controls, my satellite radio, the rear seat radio controls, or the use of my OEM rear seat DVD system.
I have herd the newer navigation system is better. Can I use that? What years did it come in?
Thanks for the help guys!!!!
