Lower ball joints on 15 tahoe 4wd
Jeramia
Foley Al.
Did a search and could not find the answer. Can the lower A arm and ball joint be removed without, removing the CV joint, shaft? Looks close, to not being to clear Thanks Jerry
OR VietVet
Multnomah Falls
Military
Willamette Valley
The lower ball joint has to come up and out of the spindle. The installed cv axle will be in the way of doing that.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Looks like if you live in the rust belt that you will be working your butt off with just hand tools. Do you have powerful air tools? It may be more than what you want to tackle if you have not done this type of work before. you tube helps with the knowledge though. It really is pretty straight forward. 35+ years in shops and I have done literally gobs of them.
I think it takes about 7 tons of pressure to press in the new ball joint. I considered replacing our own until I read that. Much easier and less expensive to change the whole arm if one does not have the air/tools to do the ball joints.
wjburken
Eastern Iowa
I have done it with a big breaker bar and a press tool set from Autozone but I would definitely go with a whole assembly next time. My shoulders were sore for a week.
Jeramia
Jeramia
Foley Al.
Great video. thanks for sharing Question-the flange on the cv joint were it bolts to the diff. Is that the same on the newer Tahoe's? thanks Jerry
OR VietVet
Multnomah Falls
Military
Willamette Valley
Looks like it is. You did not say what year your rig is so I looked at a 2017.
Tonyv__
Bucks county PA
Hate to bring up an old thread but I can’t seem to find an answer…. Are the ball joints on the 15-20 trucks serviceable or do you have to replace the entire control arm? I can only find lower ball joints. No uppers
Oh Kee Pah
MAINE
On the 2015-20 model years:
UCAs are assembled with ball joint - new UCAs is our option for new upper ball joint
LCAs can have the ball joint replaced
meandmyhoe20
