Leveled and now brakes seem off. Calipers or??
ArmedArtist
San Diego
So I finally installed my Ford Keys, Z71 coils, spacers, sway bar extenders and Bilstein 5100's. The Tahoe looks amazing now. But now that its "lifted" when I hit the brakes kinda hard, the front driver wheel seems to grab a bit more than the other side and the wheel pulls some. All the other parts on the truck looked ok. One balljoint needs replacing because of a torn boot but other than that it seems to be ok.
So think I should clean/rebuild the calipers and see if that helps? Anyone else have some front end issues after leveling?
A
ArmedArtist
San Diego
Had it done. Did the level stuff. Drive it to get new tires mounted. Then went to alignment shop.
osiris94ej
Casper Wyoming
Try and compress the pistons in calipers, check the caliper slides, other than that it's hard to say without it being in front of me.
Sent from my SM-N920V using Tapatalk
A
ArmedArtist
San Diego
It feels to me that the diver side is grabbing more then the pass side. And thats whats making it want to pull. Maybe its always done it and I just now feel it with the new Keys and a good alignment again?
osiris94ej
Casper Wyoming
If the rh front caliper has pistons that are seized it can't extend the piston effectively to produce proper clamping force on the rotor.
A
ArmedArtist
San Diego
I think from the posts so far that I am feeling the jounce gap. Should I fix that? And also now that the jounce gap is pronounced I can feel what the brakes have probably been doing for a while. Ill look into the caliper upgrade. Will I need the new booster also?
01Konvict
Boats n Hoes
Raleigh/SML
Order 07-13 front brakes and there 1" bigger so need new rotors and pads. Hydro boost is a plus but not required. Stainless steel lines helps also. Then set jounce spacers and get normal drive with hella brakes
montanaboy65
