domoarigato
- Joined
- Feb 14, 2017
- Posts
- 95
- Reaction score
- 11
Hey all,
I've noticed a very slight intermittent vibration that feels like its coming from the floorpan somewhere while driving. Steering wheel feels fine. Since I'm new to this platform, I'm hoping there are some common areas you guys can recommend that I check. It doesn't happen all the time, and I can't replicate it.
The tires are brand new Goodyear RS-A's and I plan on getting them high speed balanced and roadforced. But from my experience a tire vibration feels slightly different than what I'm experiencing but I will not rule it out.
Symptoms:
- At 65-70 mph I will feel this vibration, if I give it some gas it will go away.
- At low speeds I will feel this vibration, again goes away if I give it gas.
Possibilities:
- Tires need balancing?
- Worn driveshaft? Is this common on these vehicles?
- Worn engine / trans mounts? I believe I saw that the trans mount was replaced earlier in the maintenance records I got when I purchased the vehicle.
- I've also read that it could be AFM kicking on / off, but I didnt think AFM was on at low RPM / not in 6th gear.
Anything else I might be missing / unwaware of?
Thanks!
Symptoms:
Possibilities:
Thanks!
