Info on 2020 Tahoe PPV/SSV
Solace
NJ
Hey everyone, so 2020 is going to be the last model year for the current gen Tahoes. Due to this the 2020 PPVs and SSVs have some changes. The first big piece is that they are on a limited production run. I believe this run is only until March/April and then they will stop production to change the tooling on the production line to the 2021 models.
The 2020 PPVs also are now getting the chrome LTZ grilles to use up those grilles and keep production quick on these limited runs. The SSV will continue with the regular black grille with chrome accents on the outline though.
Silverdust Metallic has been removed as a color option for both the SSV and PPV.
Other than that those are really the only changes for the 2020 MY PPV/SSV. All codes are the same as the 2019. Sadly I don't have any good info on the 2021 MY PPV/SSV, and even if I did I wouldn't be able to release it.
fordfest
Do you know where I can find the specs on this package?
https://www.gmfleetorderguide.com/dmdindex.htm
Distribution Updates
Updates for Tahoe PPV and Special Service Vehicles
Week of 9/23/2019
Effective 9/23/2019, the following changes will be made to the Vehicle Order Guide:
  • Interior section-(TDM) Teen Driver, changed extended description to read "a configurable feature that lets you activate customizable vehicle settings associated with a key fob, to help encourage safe driving behavior. It can limit certain available vehicle features, and it prevents certain safety systems from being turned off. An in-vehicle report card gives you information on driving habits and helps you to continue to coach your new driver".
  • Week of 9/9/2019
    Effective 9/9/2019, the following changes will be made to the Vehicle Order Guide:
    • Interior section-Deleted (S0M) LPO, Illuminated door sill plates entirely.
    • Mechanical section-Added (SAB) Auxiliary Battery Relay. Is it "S" on 9C1 1FL and 5W4 1FL
Solace
Solace
NJ
Week of 9/23/2019
  • Week of 9/9/2019
The auxiliary battery relay finally being changed is a big one. Ever since they came out the previous relays were horrible to the point where GM ended up allowing dealers to replace them for free.
Solace
Solace
NJ
TCUSA
