How-to: Install auxillary reverse lights **UPDATED WITH SWITCH**
withac
Eastern Idaho
I see what you are saying now. Makes sense too. So I would take it that most switches are set up so they can not handle the 12volt load then and the relay is?
I would be using the Auxiliary HIDs for dark nights and camping and stuff so i would turn em on and leave em on for a while.
Thanks withac!
No prob Puck, I'm just passing along what others told me. Yeah, it was my understanding that it's the draw of all the watts that you don't want the switch handling, if you put a couple of 50 watt fogs on it then all that power/draw would be going through the switch, with the relay, you still have a 12 volt charge running to the switch but the flow of electricity to the lights isnt going through the switch, the electricity flows through the relay which powers up the lights, the power from the switch just activates the relay. This is just what I've been told by others who know more than I do
puckhead
CO
Sweet, makes sense. Im with you, I dont know the background of it. I can do most of it though and as long as the instructions are right Im good to go lol.
Grimes
I'm getting interested in this mod, as I certainly need the output. Would probably do the 3 way switch, as y'all seem to enjoy it. Could somebody post links as to what they are buying for this? Is it basically just any fog light housing with an HID bulb or what?
Thanks!
withac
Eastern Idaho
Thanks!
I just used cheap $20 fog lights I found at WalMart. A fog light pattern is what I wanted, low, wide,not too far reaching. If you had a different goal you could use a different type light. I’ve never done anything with HID’s but it’s my understanding they take a little bit to warm up to their full brightness, which is why they aren’t commonly used in brights that are getting turned on and off regularly if driving in populated areas. If that’s the case, and you were only using them for backing up, it would seem to me like a waste of money to pop for HID’s. Now if the goal is to really light up the area for an extended time then I guess you could use the HID’s. Even with my tinted rear window (don’t know the %, but it’s dark) the cheapies are enough that I can see as good as I need to when backing up.
Five
North Carolina
I'm looking to do this set up using two 18 watt LED light bars. If my math is correct, they'll only draw three amps so I don't see a need for a relay. Any arguments pro or con?
Cattivo
The Concrete Jungle
I would always use a relay anytime you're tapping into the trucks wiring harness because you could accidentally back feed something and cause major electrical problem$...i would recommend using a 40 amp waterproof relay...i will be using led's as reverse lights as well since i have dark tint...only i will be using the original fog light button since i am not running front fog lights
DC 12V 30/40 Amp SPDT 5 Pin Waterproof Automotive Relay + Harness Sockets | eBay
This video should help if you're not familiar with electricity
SDHanz
